Exhaust sound clips
Old 08-05-2008, 05:45 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
http://www.youtube.com/watch?v=CL1YpUWGBfo
http://www.youtube.com/watch?v=n4M44gfhXvA
Finally happy with it!
SI/ DO FlowSuper44.
3''/ 2.50''/ 3'' tips.
Old 08-15-2008, 05:37 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Here we go.
Cold start;
YouTube - F150 Cold Start / Mounting Ramps
Short acceleration;
YouTube - Driving vid for Motorhead
At idle;
YouTube - 94 F150 FlareSide Walk Around
A drive by; I plan on taking a better one sometime. I couldn't get on it like I wanted.
YouTube - F150 Passing by
Six in a row makes it go.
Old 09-09-2008, 07:58 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Here's a take off; YouTube - '94 F150 Drive Away I didn't stomp on it too hard, the motor was still cold. It wouldn't matter anyway due to the camera. It sounds totally different when I open the throttle all the way.
Check out the frame flex. I thought it was pretty good considering it's a 2wd. Ford makes some excellent trucks. Even the cheap-o models like mine are still tough. All I need now is a rear locker.
Old 10-18-2008, 10:48 AM
turdbird's Avatar
turdbird
turdbird is offline
Alright here's my true duals
96 F150 longbed single cab
both cats chopped off and true duals start where the downpipes would normally converge at the first cat, from there they each go into a walker high flow cat and continue over the rear axle and out the sides, the pipe is 2 inch with 3"x18" tips. this system has about 3 years of use on it
YouTube - True duals on an inline 6
Old 10-26-2008, 08:50 PM
fiftyfordfloored's Avatar
fiftyfordfloored
fiftyfordfloored is offline
Ok, here is my sloppy, rigged up exhaust... ready to take it to the shop and get the real one put on. Figured I'd post a clip of how the Flowmaster sounds on it, and I have to say, it ain't bad...
YouTube - Ford 300 I6 Modded w/Flowmaster
Specs:
1980 Ford F100 Flareside - 300 I6 (dur)
- Stock cam, EGR & A.I.R. Pump deleted
- Holley 470 Truck Avenger
- Offenhauser C-Series w/ 2 inches of carb-spacer
- Hedman Header
- Dual 2 inch pipes from collectors
- Cat-less
- Flowmaster 40 series (2 into 1) with 3 inch exit, dumping behind rear of the cab.
High idle ~850-900 RPM, Revving to 3400 RPM, and Idle with Load at ~500 RPM
Old 12-02-2008, 09:43 PM
TallPaul's Avatar
TallPaul
TallPaul is offline
'95 F150 4.9L. Only mod is the muffler, a Flowtech Raptor, with short pipe exit in front of rear tire. Several clips:
300 w Raptor, sound clip
Old 12-13-2008, 08:13 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
YouTube - Snow plowing Gone Wrong I know, I know, sorry to waste yer time with my sound clip.
Old 12-31-2008, 08:16 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
I thought this made a good sound clip so I decided to post it here.
YouTube - Locked 4x2 Part 2.
Old 01-10-2009, 04:18 PM
fiftyfordfloored
Finally got a new clip up of my truck.
Ford 300 I6 Modded w/custom Gibson exhaust
It lost some of the muscle car sound, but it's a lot nicer on the inside taking a long trip (and my truck is a Custom, which means no sound proofing).
Old 04-14-2009, 11:40 AM
crestfallinman's Avatar
crestfallinman
crestfallinman is offline
just got a video of my new exhaust, it aint much but its good for me
glasspack into a 3 inch tip
YouTube - 1994 F150 with the 300 Inline 6
keep in mind it is a cold start
Old 04-14-2009, 04:40 PM
crestfallinman
ok got the better one up and try to ignore the whiny power steering pump, it decided to be be extremely noisy as soon as i started filming
YouTube - truck walk around and exhaust
Old 05-05-2009, 05:01 PM
rockin300's Avatar
rockin300
rockin300 is offline
see if you guys like these
YouTube - 94 f150
YouTube - 94 f150
  #28
Old 06-30-2009, 11:36 AM
rockin300's Avatar
rockin300
bill my truck sounds fine without cats and a single glasspack
http://www.youtube.com/watch?v=0hsg4SDoUYc
  #29
Old 07-23-2009, 04:28 PM
fiftyfordfloored
Got the new engine in, finally worked most of the bugs out of it so I decided to post a new exhaust clip:
http://www.youtube.com/watch?v=ssLcysape6w
  #30
Old 08-19-2009, 12:25 AM
vincenthp's Avatar
vincenthp
vincenthp is offline
1965 f100 300 6 cylinder
Exhaust is single into dual, out behind rear axel no mufflers.
http://www.youtube.com/watch?v=ZhL0jJ7krhA
Quick Reply: Exhaust sound clips
