Sponsored by: Real Truck
Do I have auto locking hubs?
Old Apr 26, 2008 | 09:34 PM
jinxie's Avatar
jinxie
Hi
On this 02 F250 Crew I purchased, the 4x4 only works when you manually engage the hubs. However, the hubs also say Auto on them. It has the switch on the dash. Sorry, this is my first Ford....please explain what this means??!!
Old Apr 26, 2008 | 09:39 PM
high ho silver's Avatar
high ho silver
Your truck is equiped with ESOF or electronic shift on the fly. With the hubs set to auto it can be engaged by selecting the switch on the dash or should anyway. Sounds like you have a vacuum leak which is common with ESOF keeping it from engaging from the dash.
Old Apr 26, 2008 | 09:43 PM
Cobra Highboy's Avatar
Cobra Highboy
If they say auto on the hub then they are auto hubs and you should be able to just switch it into 4 wheel without manually turning them. Generally you use the auto for slick or Icy driving. When you are putting an extreme amount of torque on them such as hard 4 wheeling and things like that you are supposed to manually turn them in. If they only work when manually turned in you might need to get them serviced or at least checked out to see if something is messed up inside. Hope this helps.
Old Apr 26, 2008 | 09:49 PM
jinxie's Avatar
jinxie
So the drivers side isnt holding a vacuum. Looks like the seal came out the back of the hub. How big of a job am I looking at?
Thanks
Old Apr 26, 2008 | 09:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
Why don't you start with cleaning and lubing them first.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
The LOCK position is not any "stronger" than the AUTO position. You need to manually lock them in more severe driving or whatever. They are in case you get stuck and cannot get the small amount of forward motion needed to lock them in or if they fail to lock in automatically for whatever reason.
Old Apr 26, 2008 | 10:12 PM
jinxie's Avatar
jinxie
Funny thing is i just paid to have the upper ball joints done and this seal replaced!! I look at the back of the hub and the seal just seems to have popped out?
Live and learn....at least the bolts shouldnt be rusted!
Old Apr 27, 2008 | 02:31 AM
GregsSD's Avatar
GregsSD
My seal popped out on one of my hubs too! I was still under warranty so I just had the dealer fix it but the best thing you can do is put on some Warn locking hubs so you don't have to wonder if your hubs will work when you need them to.
If you just replace the seal, it's only a matter of time until the same thing happens again!!!
Old Apr 27, 2008 | 08:42 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Put your hubs in auto, start truck, put ac on, turn switch to 4x4, wait 20-30 seconds. If your ac vents default to the defrost vents you have a vacuum leak. Lets take this one step at a time.
Old Apr 28, 2008 | 10:03 PM
johnf350diesel's Avatar
johnf350diesel
its a pos system. i have it too. have had half of it replaced already. next time if the warranty doesnt cover it im getting warn hubs
Old Apr 28, 2008 | 10:07 PM
superduty4x4's Avatar
superduty4x4
I like the idea of Warn hubs, but I gotta admit I'm spoiled by just being able to flip the switch and have 4x4... never thought I'd be in the "too lazy to lock in my hubs" crowd but somehow I got there! My system is currently functional and I hope to keep it that way.
Old Apr 28, 2008 | 10:18 PM
afreemanmd's Avatar
afreemanmd
this may seem too simple, but my auto hubs stopped working, and in the end all that had happened was the little plastic piece that connects the rigid vacuum line to the flex line at the wheel well had busted (although you had to look carefully to see). I ended up putting in Warn hubs, but it would have only been like a $10 fix. Just a really easy thing to check
Old Apr 29, 2008 | 12:43 AM
jinxie's Avatar
jinxie
Whats wrong with the auto hubs when they are working?
Passenger side holds a vacuum when I test at the line in the tire well. Drivers side leaks immediately....cant even pull a vacuum. When I look underneath, I can see the seal, it looks as if it has backed out. I will have to disassemble to see for sure what is going on.
Old Apr 29, 2008 | 07:05 AM
redford's Avatar
redford
FTE Leadership Emeritus
When they work the auto hubs are great. The problem is they fail when you need them the most, they are very unreliable.
A lot of the problem stems from under-use or lack of maintenance. Guys who use the ESOF at least weekly and pull the hubs every 30k miles or so to lubricate the hubs seem to have the fewest problems.
