Motor mounts
Old Apr 26, 2008 | 03:46 PM
germanford390custom's Avatar
germanford390custom
Motor mounts
Hello,
Quick qestion, I have a 74 Ford F100 Ranger XLT, 390, 2BBL, C6, 2WD. The drivers side motor mount seems to have come un-done from the engine, what bolt and thread would I need to replace it with?
Old Apr 26, 2008 | 04:07 PM
fastfarmer's Avatar
fastfarmer
As I recall it's 7/16 X 1 corse thread. Takes two bolts. Is it missing bolts or is the motor mount broken?
Old Apr 26, 2008 | 04:13 PM
germanford390custom
Motor mount is completely in tact! It's just missing bolts.
Old Apr 26, 2008 | 04:30 PM
Tedybear's Avatar
Tedybear
If you have another ride available? See if you can remove one from the passenger side, make sure it fits into the drivers side correctly. If so? Head down to the parts store and get a few. Ensure any lockwashers used get replaced. It's kinda odd to have the bolts just fall out.
S-
Old Apr 26, 2008 | 04:51 PM
germanford390custom
That's what I thought, my thought is I bought it that way! Cause, the guy I bought it from gave me a replacement mount, but the mount looks fine! I think he dropped the old engine back in before he sold it to me and only secured one side.
Old Apr 27, 2008 | 06:35 AM
76f350spercamprspeal's Avatar
My Mouter Mounts Broken,Eiether that one or my Tranny Mount!
Yes I know I spelled Either Wrong!
Your Friend
76SCS.
Old May 3, 2008 | 03:35 PM
germanford390custom
Ok, I have an update... I got under there AFTER getting the new bolts. Found out there are bolts in that mount, it just seems as though they're not holding to the block anymore. I can't seem to get the old bolts out either. I don't know what to do.
Old May 3, 2008 | 03:41 PM
fastfarmer's Avatar
fastfarmer
Do the old bolts turn and not come out or do they not turn at all?
Old May 3, 2008 | 03:45 PM
germanford390custom
They don't seem to turn at all.
Old May 3, 2008 | 03:50 PM
rsalter66's Avatar
rsalter66
(Yes I know I spelled Either Wrong!)
Your Friend
76SCS.
You Spelled MOTOR wrong too friend-O
Old May 3, 2008 | 03:54 PM
fastfarmer's Avatar
fastfarmer
I think it's time for you to jack the engine up a little bit and see what is attached and what isn't.
Old May 3, 2008 | 04:04 PM
germanford390custom
Good plan. How do I jack the engine up (without a cherry picker) without damaging the engine or oil pan?
Old May 3, 2008 | 04:16 PM
fastfarmer's Avatar
fastfarmer
You can make a U shaped cradle out of scrap wood (2X4 - 4X4) or steel. Build it so that it will just slip along side of the oil pan and you will jack on the pan rails on the block.
Old May 3, 2008 | 04:36 PM
germanford390custom
Ok, I'll give that a try. I'll keep ya'll posted.
Old May 3, 2008 | 04:51 PM
Dr. Dirt's Avatar
Dr. Dirt
german390fordcustom are you a ford or chevy man? just kidding. i bet that 73 C10 is fassssssssssttttttttttttttt
