Oil Leak
Old Apr 26, 2008 | 10:05 AM
jbannister's Avatar
jbannister
Oil Leak
I have a '96 F150 XL, reg cab, 2wd with the 4.9l I6 and E4OD trans. I purchased it a couple months ago and have noticed an oil leak. The oil pan is covered in oil grime and so is the trans. There is oil grime all along the pan seal and it goes up the engine the block. The same is happening where the engine and trans meet. I'm thinking this is bad news. Do I need to replace the oil pan seal and trans seal? Could there be a worse underlying problem? How much would it cost to get this fixed and is it worth it?
Thanks,
-Josh
Old Apr 26, 2008 | 11:04 AM
netscaner's Avatar
netscaner
The first thing I would do is get some "Gunk" engine degreeser and clean off the entire engine, top to bottom.
Then you can start to figure the source of the leak.
It might turn out to be simply valve cover gaskets.
Old Apr 26, 2008 | 11:38 AM
Lazy K's Avatar
Lazy K
Or, simply, a front crank seal.
