e40d swapping blues
Old Apr 26, 2008 | 07:43 AM
thomas k's Avatar
thomas k
e40d swapping blues
i have a90 f150 im swapping trannys ibought a 1992 e40 out of e250 van mine is gear dive speedo in tail shaft 92 is magnetic how can i make mine work
Old Apr 26, 2008 | 08:54 AM
icrman's Avatar
icrman
Not sure if the tail housings and output shafts interchange between the 2, that is a major transmission overhaul to accomplish. Or change out the instrument cluster and what ever else is required to make a new electronic speedo work. Or look for the correct transmission. Maybe someone makes a conversion kit. Don't know.
Old Apr 26, 2008 | 06:25 PM
thomas k's Avatar
thomas k
thanks looking for correct tranny sounds best of the three
Old Apr 26, 2008 | 07:34 PM
95F350XL's Avatar
95F350XL
Just swap your tail shaft housing, you will have to put ur speedo gear onto that one. You shouldnt have a prob.
Old Apr 26, 2008 | 07:50 PM
thomas k's Avatar
thomas k
still wont have a gear on the shaft by re placing just the housing the housing is the same its the shaft thats differant the magnetic one is a smmooth shaft while the gear one has a worm gear can the shaft be changed some how without complete tear down
