Sponsored by: Kumho
Front End Problem???
Old Apr 26, 2008 | 01:07 AM
fenix1's Avatar
fenix1
Was walking towards the front of my 88' 4wd Bronco II the other day and noticed something that looked really wierd. The top of my front tires are leaning inward, looks sorta like an inverted v.../\. Doesn't seem to be any excessive tire wear but I know this probably isn't normal. I have a Dana 28 front end. Any suggestions? Would really appreciate some help.
Old Apr 26, 2008 | 01:31 AM
JJ98's Avatar
JJ98
hay whats up not to big on 4#4 but have work on millitary stuff hummvs and all tha stuff i would jack up your bronco and see in you can move the tire in and out or side to side could be bad ball joints or bent tie rods just look and see if any thing has play when you move that side of our bronco or but sounds like tie rod or ball joint at worst con troll arm bushing good luck
