My truck has a 351W out of a 1978 Mustang in it now instead of the factory 302, which litterally melted down in 2000. I want to make the engine to High Performance, I need to know where I can find High Output Heads, Cams, Cranks, & Intake Manifolds. I know Jegs sells the stuff for a 302, but I'm not too sure about adding that stuff to a 351W. The truck right now has the factory 302 Intake manifold and injection system on it, but I am wondering, if I make it High Perforance, what all will I need to change, if any. Also I was wondering, can I put a 351W Fuel Injection system on it, with the 302 wiring harness and computer control module. Please let me know.
if iam right a 351 is just a stroke and a head change from a 302 butt go to you parts store and pick up how to build a ford small block book the hipo book it has a lot of info sound like that might help you on your way good look
If your going to change all those parts, your also going to need better fuel injectors and a better exhaust to really get any advantage of the other parts. Yes you can use the 351 FI system (as long as your new intake is FI), but you'll need the 351 control module, not the 302's. Bigger throttle body is a must too.
Fairly sure summitracing.com has many of the parts your looking for.
Any numbers on the block he can check to see which moter it is?
Not to go off topic, but... Ford should have made the 2.8L the base motor in those II's not stick some anemic 4 banger in it, it's a mustang after all! Dont know why but II's make me think of Charlies Angels.
Measuring the stroke is the only way to tell, because casting numbers cannot be cross referenced to part numbers.
Ford supplied all the cars for shows like Charlies Angels, Rockford Files, etc. Lorimar was the production company.
The dealer that supplied the cars for these TV shows was Walker-Buerge Ford, 11800 Santa Monica Blvd in West LA. It's just Buerge Ford today.
Charlies Angels: The office building where the cars were shown parked in front of, is on Little Santa Monica Blvd, south side of the street, 2 blocks west of Wilshire Blvd in Beverly Hills.
I can tell you right now you don't have a 351 if you have a 302 intake on it, the 351 is about 3' wider across the lifter valley, so is won't bolt up.
There are lots of aftermarket performance parts available for both motors, heads, cam, and intake will take you well beyond the capability if the stock EFI system however, so this will also have to be ugraded. You didn't say what year year truck is?
The only thing I know, is when my father purchased the motor back in 2000, when the POS 302 melted down, the guy he baught the 351W from, said it was out of a '78 Mustang. That does sound a little odd, because the only Mustangs with the V8, were the Boss 302's. I have owned 3, 302V8's, all of them, did not amount to a hill of anything. That is why we did away with them and stuck with the 351W. Now I have a question for you, if I wanted to put a 281, let's say out of a 60's model mustang in that truck, would it fit, especially with the EFI that's on it right now?
No Mustang used a 351W engine after 1973 = none.
1974/78's are Mustang II's and only came with the 4 cylinder 2.3L, V6 2.8L and (1975/78) 302.
Let me ask you all this, if you had a 1989 Ford F150 Regular Cab, Long bed with a 302, espescially a low speed rear end, what would y'all do, in order to up the horsepower and torque to for one save fuel and still get about the same amount of power? I don't know very much at all, when it comes to fuel injections, I know carburators and stuff like that, but I'm not much into the Ford's past '84. I do know this much, that in 1985 is when Ford started putting fuel injection systems in all of their vehicles. Because I had a 1985 Mercury Cougar XR7 Turbo coupe, that had a 2.3L4 that had a fuel injection on it.
Headers and flowmaster or similar exhaust system, high flow cat. Same or better mpg, and better power. Bonus they sound sweet and you dont need to change anything with the stock FI. Down side, getting the old exhaust manifolds off if you do it yourself.
When you say low speed rear end, do you mean low(numerically) gear ratio, like 2.73 or 3.08? If so you're fighting a battle you can't win with a small displacement engine. With a 289 or 302 the truck will putter around and get pretty good milage but it'll never be mistaken for sporty. The way to get performance with a small motor is with gears, if you have an OD tranny you can get away with as much as 4.10's, but without I wouldn't go beyond 3.55 for the sake of hwy milage.
The next thing I'd suggest is to swap the heads on the '78 302 you have for the late model E7TE heads found on nearly all SBF's after '87, this will bump compression slightly and improve airflow. Then you have to change the cam.. it's not helping, something like the CompCams 31-255-5 is a good upgrade and is EFI compatable. Combine all this with a decent exhaust system and the truck should return close to 20mpg at hwy cruise and mid teens city driving, and be a lot more fun to drive.
