#'s on rear-end
Old Apr 25, 2008 | 05:20 PM
SportCustomWalt's Avatar
SportCustomWalt
Exclamation #'s on rear-end
I've a 72 F100 short wheel base and i'm wanting to know what the numbers on the tag that is attached to 9" ford rear. The tag has WDN-S 9MA
3 25 9 313A
Old Apr 25, 2008 | 05:37 PM
blue68f100's Avatar
blue68f100
The 3 25 means 3.25:1 ratio. with the 9 being Ford 9". Don't know what the 313A stand for.
Old Apr 26, 2008 | 05:42 AM
jowilker's Avatar
jowilker
SCWalt this site can give you something to read up on. Kevinstang's Ford Nine Inch Differential Page +
John
Old Apr 26, 2008 | 06:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by SportCustomWalt
I've a 72 F100 short wheel base and i'm wanting to know what the numbers on the tag that is attached to 9" ford rear. The tag has WDN-S 9MA 3 25 9 313A
Look at that tag number again, there is no such number of WDN-S listed in any 1957/87 Ford car or truck parts catalog.
It should read WDM-S
WDM-S = Ford 9" / 3.25-1 / Non Limited Slip / Large wheel bearings / Large differential bearings / 28 spline axle shafts / Used before serial number J30,001.
Why is the axle ID tag and serial number important?
After J30,001, Ford went to "Slim Line" differential bearings, and changed the case.
Your truck uses B7A-4616-B diff brg cups (Industry # LM603011) and B7A-4621-B diff bearings (Industry # LM603049)
These are the largest 9" diff bearings used. Besides the "Slim Line," there were medium sized bearings also used.
Sorry to be so technical, but when Ford changed the *&^$ case and bearings, it was a PITA, because most ppl and autoparts stores back then didn't know the difference, and sold the wrong parts, and still do today.
btw: Some ppl here think I list too much info, but too much info is better than no info, or wrong info!
Old Apr 26, 2008 | 09:39 AM
sub44ofrd's Avatar
sub44ofrd
Don't listen to "those ppl" numberdummy...I like to much info, you seem very informed and the knowledge is appreciated!
aaron.gwin
Jul 23, 2014 11:41 PM
sonny1965
Apr 17, 2014 04:26 PM
Lex2002
Jul 14, 2013 09:41 PM
weldworks54
Jan 31, 2012 08:43 PM
greatdays2gether
Sep 18, 2010 02:03 PM
