Sponsored by: Auxito
Strange Noise
Old Apr 25, 2008 | 05:05 PM
Sethman33's Avatar
Sethman33
Strange Noise
I know this may sound strange to many, and probably hard to diagnose, but I am wondering if someone may be able to help. I have a 2003 4.2L F150, and it is making a strange whining/bad bearing noise when at idle. It seems to happen once the truck is warm, and it is intermittent. When I turn the A/C on it seems to become more obvious. What could it be?
Old Apr 26, 2008 | 08:24 PM
bigblock_drock's Avatar
bigblock_drock
maybe bad pulley, maybe powersteering low on fluid?
Old Apr 26, 2008 | 11:31 PM
Sethman33's Avatar
Sethman33
I don't actually think it is a pulley or bearing. It almost sounds like a thin metal cover vibrating. Today I noticed that it happens when I turn the AC on. Well, it is not so intermittent when the AC is turned on. Thanks for the reply by the way.
Old Apr 30, 2008 | 07:41 PM
02crew's Avatar
02crew
chech your heast shields on your cats
Old Apr 30, 2008 | 07:50 PM
b2_tim's Avatar
b2_tim
Could be shield or ...
Remove your driver side engine hoist bracket. My noise went right away. Good luck.
Get-R-Done
Old May 1, 2008 | 09:21 PM
Sethman33's Avatar
Sethman33
Hey just wanted to update. I am actually thinking after getting up under the truck tonight while it was running, and I am thinking now that the catalytic converter cover is what is vibrating. And when I turn the AC on, it gets worse. Its the cat on the passenger side, and it is close to AC parts. SO what can I do to fix this?
