Upgrading Electrical Systems
Old Apr 30, 2008 | 08:18 AM
  #31
dave boley's Avatar
dave boley
Good Choice...
Originally Posted by Mick1930
God bless the single wire alternator!
I was also given the GM single wire alternator as the last option..but to me this is the first option...
No sparks at the neg terminal on the battery when connecting and the alternator is now putting out 13.5 on the volt meter.
So it seems I have gone around what ever wire or issue I had with this new wire harness and the out side voltage regulator setup.
So far so good and everything seems to be working.
Glad I gave this a go..but also glad the single wire alternator option was there for me to use.
Way to go Mick,
You done good. I think that was your best possible option. I use those things on everything. I'm not a darksider or a GM guy but I do like those alternators. I don't care if they are different, with a welder, a milling machine and a lathe I'll make 'em fit whatever I'm workin' on.
Old Apr 30, 2008 | 08:44 AM
  #32
dave boley's Avatar
dave boley
Solenoid Relays...
Originally Posted by Sandidande
Your positive Battery cable should be connected to the post that has a 'B' by it. The one with the big lug and isn't going down to the starter.
And yes the one wire alternator was suggested at the begining of this.
Do you have a shop manual that has the year and make of your engine? If not, you need to get one, and follow the diagrams and instructions in it. If all else fails........
Dan,
Just for the sake of clarity here, I though it migh be a good thing to explain why the connections have to be as they are specified on the solenoid relays. If you have ever taken one of these things apart you will see that it is a very simple, and quite primative device. The mounting bracket supplies the negative connection for the coil and the small terminal marked "S" is the positive source for the connection. The contacts are the ends of the two heavy posts for the starter and battery connections. When the coil is energized it pulls down a simple copper washer to connect the two posts. If the solenoid has a small "I" terminal it is also contaced when energized. They make these things with and without the "I" terminal. When used, it bybasses the ignition coil balast resistor to compensate for the lower voltage during cranking. The more modern electronic inginitons have done away with the need for this terminal. You can use the older type withn the "I" terminal on the newer systems so long as you don't try to use the "I" terminal itself. If you have the old point and coil type ignition system with the ballast resistor you will need to use the old style solenoid relay. Of course the later Ford products have gone to the GM type starter with the solenoid being on the starter where it performed two functions. The same connections are on those starter solenoids.
This may not be of value to anyone if they aren't trying to mix and match parts from different systems, but I have been asked about this before. Hopefully it will help someone here.
Shutech
Apr 21, 2015 09:31 PM
Smirks90
13
Nov 1, 2014 05:11 PM
old broke prospector
Apr 9, 2013 07:43 AM
dotculf
Electrical Systems/Wiring
May 1, 2005 11:41 PM
