Found a great place for Ford F150 questions/TN & MI
I have a 1995 Ford F150 V8 5.0 302 with dual fuel tanks. Over the past month, while driving, on 4 separate occasions the truck just quits.
It's almost like you just turned off the ignition. You can try to start it and it turns over but does not start.
On 3 of the previous occasions it started back within 5 to 10 minutes. But the last time, I backed out of my parking space, put it in drive and pressed the gas pedal and it quit immediatedly. This time it did not restart even after waiting 2 hours.
I had it towed to the Ford dealership and left overnight. I went in the next morning and gave them the key to service the truck.
Amazingly, they called back later and said the truck started just fine and they have been driving it around and they cannot get it to fail.
I have put in a new filter and plugs before the last incidence.
Any ideas?
Any ideas?
Last edited by guyfulcher; 04-25-2008 at 12:30 PM. Reason: Left off the duel fuel tanks & misspellings
Received 1,392 Likes
on
Hi and welcome guyfulcher.
Sorry to hear of your truck troubles, since you`ve posted this inquiry in the 1987 - 1996 F150 And Larger F-Series Trucks forum help is on the way.
Swing by your local TN chapter to meet some good folks there too: Tennessee Chapter - Ford Truck Enthusiasts Forums
Be sure to fill in the location field in your profile too.
on
Hi and welcome 1jtaylor.
For tech help on your truck repost in the 1997 - 2003 F150 forum: 1997 - 2003 F150 - Ford Truck Enthusiasts Forums
Your local MI chapter awaits you, jump in and join up: Michigan Chapter - Ford Truck Enthusiasts Forums
