hpop leak
Old Apr 25, 2008 | 12:27 AM
jupiter1's Avatar
jupiter1
hpop leak
Fixed mine today. Was leaking at the forward o ring. The ring was pretty messed up. Leak started suddenly, got progressively worse in a week from a dime size spot on the driveway to a dollar size. Upon inspection it was pretty clear where the oil was coming from. Easy fix, took about 2 hours. Hardest part is releasing the hoses from the fittings if you don't have the factory tool. I used a similar tool and managed. Also, cleaning the ports was easiest for me with a wooden qtip sprayed with brake cleaner, be patient.
Old Apr 25, 2008 | 12:57 AM
Fomoko1's Avatar
Fomoko1
Hi and welcome jupiter1, congrats on your fix. I was wondering what this post was about it till I saw your other one.
Swing by your local WA chapter soon and check it out: Washington Chapter - Ford Truck Enthusiasts Forums
Be sure to fill in the location field in your profile.
bronco1994
New Member Introductions
Aug 3, 2008 12:17 PM
Flowmastr
May 5, 2008 01:04 AM
happycamper62
Apr 8, 2008 11:42 AM
outlaw30830
Apr 2, 2008 08:13 PM
chairman13
Mar 10, 2008 01:07 PM
