Hardened Valve Seats
Old Dec 20, 2001 | 01:11 AM
bufordt's Avatar
bufordt
Recently I helped a friend of mine put a rebuilt 302 in his 87 F150 EFI. We finally got it going to realize the head gaskets were blown, so we sent the heads of to a machine shop and they checked out good except they didnt have hardened seats. My question is how long do you think the soft seats will last without running leaded gas? I know you can be lead additives but they wont work with the EFI will they? My friend is a college student so he dont have the $400 to put the harden seats in?
Old Dec 20, 2001 | 04:51 PM
Red Rocket's Avatar
Red Rocket
Hey man,
How did you have a rebuilt motor with a blown head gasket? I have ran unleaded in my 67 mustang and my 67 and 73 International scouts with no problems.
Old Dec 21, 2001 | 12:45 AM
bufordt's Avatar
bufordt
The vehicle it was in before he let it get to hot. But thanks for the input none the less.
Old Dec 21, 2001 | 09:28 AM
Franklin2's Avatar
Franklin2
If you use the truck for normal driving with ocasional hauling, the heads will last a long time. If the truck is worked hard with lots of heavy hauling, it will aggravate the seat problem. What will happen over time, is the valve will slowly pound itself up into the seat, till the lifter is not able to adjust itself any more, then the lifter will start not letting the valve close all the way. Eventually it will burn the valve and cause a miss in the engine. But the time limit is how hard you run the engine. These must be an old set of heads somebody put on to raise the compression ratio of the engine.
Old Dec 21, 2001 | 09:22 PM
Franklin2's Avatar
Franklin2
