Where do most people put the probe? I thought it when in the pan but the place that did my trans said put it in the line running to the trans cooler...
I dont even have a port on my trans pan to put the probe in Im told, so I gotta figure out what I need to do.
Options are
1. take the pan to get drilled and taped
2. put in the line like I was told by my trans shop (no idea how to do this though)
3. drill and tap myself and hope I dont break anything.
You place the probe in the test port on the drivers side of the transmission. There is a plug you remove and you install the probe right inside of it. No drilling no tapping nothing. Someone should have pictures.
Thats what I thought, but Im not doin the install since I dont have the time with work and all and that was what I was told. Will make a phone call tomarrow then, Thanks
Chris.....that is the easiest of the 3 to install with the normal gauges. Just pull the plug, screw in the sensor, and run your wires! Just have some rags ready to catch a little fluid!
Yea well I didnt look it up and was just goin by what I was told.... not enought time off from work and Ive had the gauges since nov and still havent put them in so I sucked it up and paid someone.
This is some information I got from FTE member Mark Kovalsky when asking the same question...
"I've measured temps in the pressure port, the pan, and the lines to and from the coolers all at the same time.
The pressure port and the pan temps are very close almost all the time. The line to the cooler will have HUGE temperature fluctuations. When the truck is under load and the torque converter unlocks you can expect a quick rise, often to well over 200F. What are you going to do about that? It's normal operation, but to those that don't know a lot about transmissions it sure can be scary. Adding a large cooler won't help this at all.
I like the sender in the pressure port. It gives the bulk temp of the trans, not the hottest spot, which to me is much more useful. The temp in the cooler line is the hottest spot, but that doesn't mean much for the life of the trans, the bulk temp does.
If you are watching temps in the pressure port or the pan, 60-100F above ambient is normal, with some higher temps when the truck is working hard. If you are looking at temps in the line to the cooler 60-250F above ambient is normal.
I will point out from 2004-2007 transmission cooling was my job. I ran many cooling tests on the road, on test tracks, and in wind tunnels with vehicles with almost 100 thermocouples. I have a pretty good idea of how this stuff works. I'll bet it's a lot more than people that build some VERY good aftermarket transmissions."
Great info. Mark definitely knows what he is talking about. Anything that guy says about these tranny's should be weighted very heavily.
Reps sent to you for digging that up. I have already rep'd him for his continued expertise.
