engine service lite on part 2
well i replaced the napa cps with the gray ford sensor...same problem....just recieved my auto enginuity scanner. i have a head ache just reading the book...to be continued when i figure this out....cant wait to get my truck straightened out
Without knowing the fault codes, it is just a guessing game.. Does the engine ever miss and run rough..? Mine had a intermitted miss and SES light and code of P1316. It was the under the valve cover plastic junk of a connector just separated by almost a 1/4".. easy to fix.. no parts for buy. You can reuse the valve cover gaskets.. I just made a shim to slip behind the locking tabs (which warped from the heat and oil).. see my pic gallery for a loose and tight connector and home made shim..
