Alternator Problems?
Old Apr 22, 2008 | 09:42 PM
smythcounty's Avatar
smythcounty
1998 Ford Expy 5.4
Last week after I shut off my vehicle to run into the store and came back it wouldn't start. Got a boost and it started fine but was only showing 10 volts. Went to auto store when put load on alternator vehicle died. Replaced alternator everything was fine for 5 days. Drove the vehicle 200 plus miles with no problem. This evening after I started I noticed that it was only putting out 8 volts so I parked it. My question is do you think I could have gotten a bad alternator or could something else be "frying" the alternator. Bought a reman from local auto parts store.
Old Apr 23, 2008 | 11:09 AM
buzzard's Avatar
buzzard
Sounds like a bad alternator. Swap it out again (should be covered by warranty) and see what happens.
Old Apr 23, 2008 | 11:49 AM
smythcounty
Ok I'll do that I also search on here and some people were saying to check a fuse and battery cables. Thanks
Old Apr 23, 2008 | 08:19 PM
smythcounty
After being stranded, borrowing vehicles and buying another alternator the problem was simple. When I began to disconnect the wires from the "bad" alternator I went to grab the one with the spring clip and it wasn't even connected. I guess it didn't snap the other day when I installed it and it worked it ways loose. For once it was something simple for me. Remember to check those connections....
Old Apr 25, 2008 | 09:38 PM
mywifesexpo's Avatar
mywifesexpo
Don't feel bad. I had the same problem.
gumbydamit
Electrical Systems/Wiring
13
Dec 22, 2021 08:45 AM
jonnygorgo
29
Mar 12, 2014 06:36 PM
Desertelkhunter
Aug 23, 2009 04:16 PM
iacowboy
Apr 17, 2008 05:50 PM
RXRR
Feb 20, 2004 03:27 PM
