Sponsored by: Real Truck
05 Air conditioning Problem
Old Apr 22, 2008 | 08:37 PM
csx6025's Avatar
csx6025
My 05 diesel powered truck has a problem of keeping the air coming thru the panel vents. It starts out fine but will shift to the defrost vent or shuffle back and forth between them sounding like a helicopter in the cab. This truck has EATC. I have checked the vacuum motor for the panel, it's O.K. Vacuum pump is working properly. I have narrowed it down to the electric solenoid/vacuum manifold or the connection between it and the vacuum harness. Has anyone else experienced this problem? Thanks. David.
Old Apr 22, 2008 | 09:15 PM
wiingnut's Avatar
wiingnut
I experienced the issue before and the head unit was replaced. I also had the unit totally go out with original unit. If under warranty have them replace before it's up. good luck
Old Apr 22, 2008 | 09:25 PM
csx6025's Avatar
csx6025
Thanks wiingnut. My head unit went out 2 years ago and was replaced under warranty, however I'm out of warranty now. My head unit would go out totally or it would work o.k. It was intermitent. But did not have the same symptoms as now. My air never quits, just goes back and forth between panel and defrost.
JTF150SC
18
Apr 11, 2018 11:15 AM
turnkyle
Feb 1, 2014 05:57 PM
mike2112
Apr 13, 2011 07:09 PM
kw5413
Jul 25, 2005 10:49 PM
blgrable
Aug 29, 2004 03:53 PM
