Sponsored by: Real Truck
I did back up lights too.
Old Apr 22, 2008 | 04:03 PM
ReAX's Avatar
ReAX
I mounted a pair of Piaa Solitare oval lights on my hitch. Install went pretty good, I used #8 self taping bolts and a couple of washers to get them even. For power I used the included relay, I tiewrapped it up to one of the big connectors, cut off the ground going to the switch. I ran the constant power to the orange wire on the round plug, and the trip wire to the blk/grn wire in the middle of the round connector. The ground was just the right length to go back to the factory ground on the drivers side frame rail.
Over all, a pretty easy mod.
Old Apr 22, 2008 | 06:22 PM
ReAX's Avatar
ReAX
I think tomorrow I'll start the fronts. I have some old 1700x Piaa. My truck had fog lights before the semi-hidden winch kit went in, but I still have the wiring for it. I am going to tap the stock wiring for the relay trip. I am a little unsure how I am going to mount them. I measured up some 1" aluminum square tube to screw into the warn bumper reinforcement. I can only get one screw in it, but I have plenty of stock left. Any suggestions?
