EGT Question?
Old Apr 21, 2008 | 09:16 PM
F-SUPER DUTY's Avatar
F-SUPER DUTY
EGT Question?
Got my pyro installed.What affects EGT's?Will outside temp. or load affect my EGT?Or is it just affected by overfueling?
Old Apr 21, 2008 | 10:00 PM
George D.'s Avatar
George D.
load will efect egt because you will need more fule to keep speed or accelerate.
Old Apr 21, 2008 | 10:59 PM
catfish101's Avatar
catfish101
It's that thermodynamics thing. The more fuel you inject creates more heat and the hot air in movement is what turns the turbine rotter on the turbo. The hotter the air the faster it moves.
Old Apr 22, 2008 | 09:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Outside air temp can have a small impact on EGT.
How much fuel, what RPM the engine is running, and how long the hill you are pulling how much weight up have a bigger impact on EGT.
How restrictive your exhaust pipe is has a bigger impact on EGT than ambient air temp does.
Old Apr 23, 2008 | 07:43 PM
F-SUPER DUTY
Thanks for the input dave.Ill try to get it set up so its about 1200 up hill at high rpm.
