Downpipe is finally in!
I also just put mine in, on Saturday. I was not looking forward to removing the old one, but it came out real easy. I didn't even have to cut it up above like I've read you have to. I couldn't find a good angle to get the sawzall that would cut all the way through with an 8" blade. The firewall bent pretty easy, but it doesn't look quite as good as I'd hoped. Removing the cat was what took forever. It would not separate from the pipe behind it. When I finally got it apart, I couldn't get the new pipe slid in as the clamp had squeezed the pipe some. Lots of heat and prying finally got it so it would go together.
I didn't notice a big difference. A little more turbo whistle at slightly lower RPMs is all. I don't have an EGT guage so I won't know what the difference was there. It'll be worth it though when I get other mods done.
