Sponsored by: Auxito
96 e 250 brakes draging
Old Apr 21, 2008 | 06:23 PM
geno3124's Avatar
geno3124
Hi everyone,beautiful weather down in new orleans today.
I have problems with my rear brakes.I installed new shoes and spring kit and wheel cylenders at rear ,and also changed master cyl.
The problem is that after you drive a short time using the brakes a few times,the rear wheels will bind and drag.This problem started before I changed any parts.It seames that the fluid is onyl going one way,it won't go back to the master cyl. when you release the pedel.I think my truck only has abs on the rear.Also the abs ( green light ) and the two brake symbles(red light ) are on also. There is a valve body for the abs mounted on the frame with maby a half dozen wires attatched that the line from the master cyl. goes to it on one end and a line comes out at the other end to the rear brakes.There is also a sensor mounted to the rear end chunk.Do you all think my problem is mechinical (hydrolic) or electrical?
Thanks
Old Apr 21, 2008 | 06:35 PM
Bobby82490's Avatar
Bobby82490
Are you sure they arent adjusted too much??
Also you will get more help by posting in the correct forum
1968 - Present Full Size Vans - Ford Truck Enthusiasts Forums
Old Apr 21, 2008 | 06:41 PM
geno3124's Avatar
geno3124
Bobby,I know I am at the wrong forum,but I am new herde and could not find where I should be at.But any way,the wheels will spin freely after I release some fluid at the bleed valves.It comes out under presure when I crack them open.After I stop a few times it drages hard again.???????
Old Apr 21, 2008 | 06:48 PM
Bobby82490's Avatar
Bobby82490
To tell you the truth i dont know what to tell you, i dont know a whole lot about diagnoising brake problems.
Also don't sweat it about posting in the wrong forum.. ive done it before also.
Old Apr 21, 2008 | 09:10 PM
Ultramagdan's Avatar
Ultramagdan
You found the E forum. Great!
