Backup Sensor problems
Old Apr 21, 2008 | 12:12 PM
tomw3115's Avatar
tomw3115
I have a 2004 Ford F-150. Recently, I had a back-up sensor system installed. It worked fine for a couple weeks, and then decided sound every time I would back up even though there was absolutely nothing behind me. I took the truck back to the service center that initially installed it, and they reprogrammed something. Same thing - after a couple weeks of working fine... The have since replaced that unit three times - then replaced it with a different unit - a DT 506 - no brand name. Same situation. The last two times it started doing this was after I had lowered the tail gate. Putting the tailgate up makes no difference. The sound is constant when the truck is in reverse. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Any idea what is going on with this? I have several friends with the same backup units as I initially had and were installed by the same company, and none of them have ever experienced this.
Old Apr 21, 2008 | 02:27 PM
Fomoko1's Avatar
Fomoko1
Hi tom, welcome aboard.
For help on your problem the forum you want is the 2004 - 2008 F150: 2004 - 2008 F150 - Ford Truck Enthusiasts Forums
Swing by your local IA chapter and see what`s up in there: Iowa Chapter - Ford Truck Enthusiasts Forums
trel67
New Member Introductions
Dec 21, 2007 10:16 AM
