Power Steering Pressure Switch???
Old Feb 2, 2002 | 12:45 AM
horsepower's Avatar
horsepower
When I got my truck there was a yellow-green wire and a grey-red wires with a plug on the end of them hanging loose, now I found out that it's the power steering pressure switch wires. My Haynes book says the 5.0L are the motors that have them but it doesn't say where to plug it in. So is this true does a '93 F-150 with 5.0L have the switch and if so where do you plug the wires in at?
Old Feb 2, 2002 | 01:44 PM
dpattonfl's Avatar
dpattonfl
Post Power Steering Pressure Switch???
[updated:LAST EDITED ON 02-Feb-02 AT 02:45 PM (EST)]There should be a tee fitting in the power steering pressure line with a sensor screwed into it. The wires should connect to the sensor. If you can't find one, then it sounds like the previous owner may have replaced the pressure line with one that doesn't have the fitting.
Old Feb 2, 2002 | 03:10 PM
ExplicitHP's Avatar
ExplicitHP
