fuel problem
Old Apr 21, 2008 | 05:45 AM
oldride39's Avatar
oldride39
fuel problem
sorry guys not to good on here my first time on here any way yes i have gas pushing out of the gas filler tube on my f-150 300-6 front tank I think it might be the check valve assembly is it in the front tank or is it on the rail.any help would be appreciated.
Old Apr 21, 2008 | 11:15 AM
Animalistic's Avatar
Animalistic
This is a common problem with our trucks. Mine was covered under a recall. You didn't state the year of your truck so not sure if yours is covered or not. You can go here to check:
Ford, Lincoln, Mercury and Mazda Recalls
For more info on this issue, select the first post "Read First: 1987 to 1996 Tech info " and scroll down to the "GENERAL MECHANICAL INFO" section. Then select the "on tank filling the other tank " post. You can also do a search for "Dual fuel tanks".
Good luck and welcome to the forum.
86'F-150
84
Jan 22, 2013 10:33 PM
izmepeggy
20
Dec 18, 2012 12:14 AM
RickUhrig
62
May 27, 2005 09:58 PM
joshwatts22
Mar 21, 2005 07:50 AM
ptrill
Mar 10, 2003 09:04 AM
