engine swap
Old Feb 10, 2002 | 07:43 PM
ford150hauler's Avatar
ford150hauler
engine swap
[updated:LAST EDITED ON 10-Feb-02 AT 08:45 PM (EST)]DJ ihave a 1994 f-150..i'm being told the #5 piston is cracked. is an engine swap the best way (considering money) to go? will i have major
problems swapping a 302 out and a 351 in ?
thanks, DJ
Old Feb 10, 2002 | 09:50 PM
92flaresidextracab's Avatar
92flaresidextracab
engine swap
I too have the same question for a 1992 f150. I have the 351W complete running engine out of a 1989 f150. trying to find info on a swap from the 302 to the 351W.
Old Feb 11, 2002 | 11:05 AM
loudfords's Avatar
loudfords
engine swap
I did the swap a year ago in an 87. I used the wiring harness and emissions equipment off of the original 5.0. You will want to use the accessory mounting brackets off of the 5.8, as well as the 351 exhaust. I have been running mine on the original 5.0 computer but it runs a little rich sometimes but actually works pretty good. The rest of the stuff is just plug & play.
Old Feb 11, 2002 | 05:51 PM
desperado_18_2000's Avatar
desperado_18_2000
engine swap
