Fuel filter replacement
Old Apr 19, 2008 | 03:29 PM
Million Mile Man's Avatar
Million Mile Man
Idling rough after 33,000 miles, so I picked up a new set of filters. The air was easy, but I can't find the fuel filter, and am too cheap to buy the manual.
Where is it, and are any special tools required to replace it?
Old Apr 19, 2008 | 03:39 PM
fire240's Avatar
fire240
The fuel filter should be on the drivers side frame rail near the fuel tank. You will probably need a fuel line disconnect tool to remove it. Most auto parts stores sell them now.
Old Apr 19, 2008 | 05:01 PM
f150v602's Avatar
f150v602
fire240 is exactly right. the filter is about 1 foot infront of the fuel tank on the drivers side by the frame. i just bought the filter then took it to a lube place and they changed it for me in about 5 min. charged me like 15 bucks but i think its worth it so i dont have to worry bout getting the diconnect tool or the fuel mess.
Old Apr 19, 2008 | 05:46 PM
wildcard30's Avatar
wildcard30
Try this link.... Here a how to article. LINK
Old Apr 22, 2008 | 07:21 AM
Steve_Uzi's Avatar
Steve_Uzi
Special fuel line disconnect tool.. and Follow that article because that article ROCKS! I followed it and 20 minutes and $6.99 later I had my filter replaced! Too easy!
Old Apr 22, 2008 | 09:35 AM
patriots6800's Avatar
patriots6800
Drivers side on the frame rail follow the fuel line back and you've found it, youll need the quick disconnect tool i recommend the plastic ones that slide in rather than the metal scicssor style one takes about 5 mins to do
