Can't keep fulid in my E4OD
Old Apr 19, 2008 | 01:20 AM
kdy72601's Avatar
kdy72601
Well tranny fuild started pouring out the front of my tranny about a week ago so figured it was my front pump seal so i pulled the motor and replaced it. worked good for a day and a half then it started poring tranny fuild out the front agin i'm totaly stumped is it posible i got a bad seal from the parts store or it there any other seals to check? btw why is it that when the e4od is 2 qts low it dont want to let the truck move and the c6 in my bronco has to be almost a gallon low before it starts acting up?
Old Apr 19, 2008 | 11:21 AM
sclariat's Avatar
sclariat
replace your pump bushing along with the seal. inspect the torque hub for cracks and excessive wear. check your crank for excessive runout.
Old Apr 19, 2008 | 09:46 PM
kdy72601's Avatar
kdy72601
thanks allredy inspecied the crank, converter and front plate for cracks, lines for blockages. so ill replace the bushing was going to but none of the parts stors here had it in stock so ill have them order it
