Overhead Console, Reading -40 F ??????
Old Apr 18, 2008 | 03:24 PM
quality1construction's Avatar
My overhead console is reading -40 F on the temperature, It's 74 here today, is there a sensor for this?
Old Apr 18, 2008 | 04:09 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yes, look where you would do the zoodad mod. If you look through the grill on the drivers side of the rad you will see it there.
Old Apr 18, 2008 | 04:27 PM
zx250's Avatar
zx250
Of the next Riffraff East
Try to reset the console by pulling the fuse. If that don't work, check the wiring for the sensor for any nicks or chaffing that could cause problems. Last thing would be to replace the sensor.
Old Apr 19, 2008 | 11:20 PM
Pulled fuse, no dice, come to find prior owner cut the wires to the sensor up front, hooked wires back up, works like a charm!
Old Apr 19, 2008 | 11:34 PM
F350-6's Avatar
F350-6
I can't think of any good reason to cut those wires. I wonder what else the PO screwed up.
Old Apr 20, 2008 | 12:24 AM
machmedic's Avatar
machmedic
Just did my zoodad mod the other day, I was wondering what that sensor was for. Learned something new today, thanks.
Old Apr 20, 2008 | 08:23 AM
miller_feed
Good find. As long as you get her working again, thats what matters.
