All users get 60 minutes to add or remove content in their posts.
Instead of clicking reply to make another posts.
simply click EDIT located at the bottom right of your post.
If you are just doing front and rear input you'll be fine leaving it in. The top of the TC can be reached via the top cover (the hump between driver's and passenger's seat). There is at least one plate that is on the passenger's side but faces up that might be hard to reach. Where are your leaks?
