Hey everyone I need as much help on this as fast as possible if ya'll can. I putting my truck in a car/truck show Sat. What I need from anyone who can help me on this is all the numbers and specs on the 352 in my truck that can be given to me. I plan to put up a poster board beside my truck with all of this info on it to give people and judges an Idea of what exactly is under the hood and any other details that I can think of. I have seen other people that have done this and not only does it look good but it gives you a professional apperance as well. So any help with this between now and tonight would be greatly appreciated. Thanks
What kind of info would you be after? The 352 FE was first put into trucks in 65 and lasted to 67, then they went to 360 and bigger. The motor had been in production since 1958. It is a member the FE family of engines. It has 208HP, but i can't recall the TQ numbers...
--Mike
352 FE V8 Introduced in 1958 as part of the Interceptor line of Ford V8 engines, the Ford 352 (of 351.9 in³ or 5.77 L displacement) was the replacement for the Lincoln Y-block. It was simply a 332 with 3.5 in (102 mm)stroke and a 4.0 in (88.9 mm) bore, and was rated from 208 hp (155 kW) with a 2-barrel carburetor to over 300 hp (224 kW) on the 4-barrel Police Interceptor models. This series of engines usually weighed over 650 lb (290 kg), and were all known for excellent torque and durability.
Applications:
2V
8.9:1 — 220 hp (164 kW) at 4400 rpm and 376 ft·lbf (510 N·m) at 2400 rpm
1961-1963 Ford
4V
10.2:1 — 300 hp (224 kW) at 4600 rpm and 395 ft·lbf (536 N·m) at 2800 rpm
1958 Ford Interceptor (civilian)
1958-1959 Ford
1958-1959 Ford Thunderbird
9.6:1 — 300 hp (224 kW) at 4600 rpm and 380 ft·lbf (515 N·m) at 2800 rpm
1960 Ford
1960 Edsel
1960 Ford Thunderbird
10.6:1 — 360 hp (269 kW) at 6000 rpm and 380 ft·lbf (515 N·m) at 3400 rpm
1960 Ford
8.9:1 — 235 hp (175 kW) at 4400 rpm and 350 ft·lbf (475 N·m) at 2400 rpm
1960 Ford
9.3:1 — 250 hp (187 kW) at 4400 rpm and 352 ft·lbf (477 N·m) at 2800 rpm
1964-1966 Ford
8.4:1 — 208 hp (155 kW) at 4000 rpm and 310 ft·lbf (420 N·m) at 2800 rpm
1965-1967 Ford F-Series
So how ya been grumpy ? I'm still waiting on that cowl molding for my 65 Custom Cab?
And while I got ya here. Where did the stock tailpipe exit under a 1960 short bed. Has a 292 in it. Out the back or in front of ride side tire? Or should I post it in other forum ?
Thanks for settin me straight on the FT FE. Have a good eve.
Frank
And while I got ya here. Where did the stock tailpipe exit under a 1960 short bed. Has a 292 in it. Out the back or in front of right side tire? Or should I post it in other forum ?
Frank
When I see Wiki Wiki being cited as a source for anything I'm interested in, grumpy ain't the word for what my feelings are.
The moulding is yours (I promised Don the other one) when I dig it out, and the tailpipe extended just past (or up to) the rear axle, right side on 1957/60 F100/350's, just like they did on most other Ford trucks thru the 1990's.
Even the 1952/64 OHV 6 bangers (215/223/262) tailpipes ended up on the right side.
1952/64 cars with the 215/223 engines = same-o same-o.
The exhaust (and intake) manifold on these puppies is on the drivers side.
rusbukt, You are correct the FE was introduced in 58, but as the power plant for the new Edsel car. 1965 was the year the 208 HP FE was introduced to the pickup.
