diesel additive
Old Apr 18, 2008 | 04:15 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Originally Posted by jimwilsonmasonry
can i run biodiesel in my truck without changing anything
Yes. If you're using anything for lubrication in your fuel, you will not have to with bio-diesel. In fact, bio-diesel is the best stuff out there for lubrication. I don't believe you would gain anything by adding anything to it. It will do a thorough job of cleaning the fuel system and the tank that you may need to change the fuel filter a little more often at first. In the winter, it will gel a lot quicker than regular diesel so you need to keep that in mind.
