Temp
Old Apr 17, 2008 | 07:45 PM
JethroF250's Avatar
JethroF250
Exclamation Temp
I'm goin to be towin a 7500 lb tractor on a tandom axel trailor. My mods are in my sig. Do you think my temps will be too hight? I have no pyro and want to run safe.
Old Apr 17, 2008 | 08:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I don't see anything that would cause concern. With the ICP mod you may want to ease off her on a long climb....but other than that you should be GTG.
Old Apr 17, 2008 | 10:04 PM
immastrokinnow's Avatar
immastrokinnow
where are you towing it to?
Old Apr 18, 2008 | 08:35 AM
JethroF250's Avatar
JethroF250
I'm towing from rising sun up to route 30 in pa. i'm goin to a place called rough and tumble and wanted to make sure that my temps wouldnt be too high with all my mods. i need to get a pyro soon but i aint gonna get it by 2mro. i'm not tryin to blow my pistons
Old Apr 18, 2008 | 09:55 AM
secondarychaos's Avatar
secondarychaos
This makes me wonder, I plan on installing a pyro, boost and temp guage package,
What kind of EGT's Should i see on a stock truck, towing 8k on mild hills?
Old Apr 18, 2008 | 10:03 AM
MagKarl's Avatar
MagKarl
With Tymar intake, downpipe, and 4" exhaust before I got my chip I could still hit 1200 towing my 22' camp trailer. I'd say a stock truck will hit 1200 easily when working hard. I don't think there's enough fuel to go much beyond that though.
Old Apr 18, 2008 | 10:05 AM
secondarychaos
I think im going to get the guage before i start towing that at all.
Old Apr 18, 2008 | 07:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Yeap, me too, easily 1250, towing similar trailer, with my mods, so I NEED chip. What are your numbers after the CHIP? and your settings? And I saw you have an intercooler, that first numbers was with or without the IC?.
Old Apr 18, 2008 | 09:51 PM
c00nhunterjoe's Avatar
c00nhunterjoe
there is only one decent hill if i recall the way you are going, just dont lug the motor up the hill, let it downshift and go up, you should be fine,
Old Apr 18, 2008 | 10:26 PM
JethroF250's Avatar
JethroF250
I dont have to worry bout it now. I was tryin to unbolt the hitch on the tractor so I could switch out to my pullin hitch and a damn bolt broke. How would you get a bolt out that is hardened steel broke because of me standing on the breaker bar cause it was so tight and a bolt where an easy out wouldnt even work. Drill and tap for a new bolt?
Old Apr 18, 2008 | 10:46 PM
c00nhunterjoe
does the bolt take the place of a pin? can you drive it out?
Old Apr 19, 2008 | 06:36 AM
JethroF250's Avatar
JethroF250
no it bolts into the axel housing. we beat it with a hammr while having pressure applied from an easy out. its solid didnt even move. we were trying to drill it out and it broke a diamond cut drill bit that was ment for metal. the bit broke in 2 spots at the same time and one piece hit my dad in the forehead
Old Apr 19, 2008 | 07:32 AM
c00nhunterjoe
hmm, not good, you will need to get the busted bit out first, then use a torch to heat the area around the bolt and try again
Old Apr 19, 2008 | 02:48 PM
JethroF250's Avatar
JethroF250
we got the bit out. i dont know how much heating will do though beings its so tight
Old Apr 19, 2008 | 02:53 PM
c00nhunterjoe
heat does amazing things, try not to get the bolt itself too hot, just the area around it
