How do you reinstall the cat??
Old Apr 17, 2008 | 06:28 PM
SupaDups's Avatar
SupaDups
Have an Mbrp turboback with cat delete pipe and have to reinstall the cat for inspection at the end of the month. Where do I have to start loosening stuff in order to swap it out? Thanks for your help!
Old Apr 17, 2008 | 08:29 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I think it's only the bolts in front of and behind the cat....if that isn't lose enough, loosen the brace behind the cat......
Old Apr 17, 2008 | 08:44 PM
NavyPowerstroker's Avatar
NavyPowerstroker
You can see in my gallery the installation of a cat delete pipe. You should be able to see where the cat goes and what bolts are used to bolt it in place. It should be the first set of bolts just to the rear of the skid plate under the transmission.
Old Apr 18, 2008 | 08:23 PM
slowmans's Avatar
slowmans
i have yet too put mine back in for inspection.... its passed the past 2 years!!
