help with climate control
Old Apr 17, 2008 | 02:41 PM
Brody3665's Avatar
Brody3665
I wanted to use the a/c the other day but the cold reading will not go below 60 degrees on the read out. To go along with that no cold air blows out. Think it needs to be recharged or a problem with the head unit...
Thanks
Old Apr 17, 2008 | 06:49 PM
katiesdad7's Avatar
katiesdad7
That's because the A/C can't cool the Ex that cool in the hot sun. Your A/C should be blowing cold. If it's not it could be low or the blend door is stuck. Don't forget to push the recirculate button. 60 is the lowest it will read.
