Questions about mini spools
Old Apr 17, 2008 | 10:18 AM
summitx670's Avatar
summitx670
Exclamation Questions about mini spools
i was planning on putting a mini spool in my truck. can you put one in when you have limited slip? and am i going to break axles when i go around corners? or does anyone know were i can get a cheap locker to go in place of my limited slip?
Old Apr 17, 2008 | 10:45 AM
Conanski's Avatar
Conanski
Spools are not recommended for street use, it puts all the load on the axles and the tires will skid and spin around every corner, it'll be nearly impossible to drive on the street in the rain. Have you rebuilt the TracLock? It's prestty easy to make hugh improvements in the way it works. Besides that Powertrax and Detroit make lockers that insert inside the factory carrier without removing the differential from the housing..
