ODB2 - how to..
Old Apr 17, 2008 | 02:21 AM
jhouge's Avatar
jhouge
ODB2 - how to..
Hi everyone..
I have a few questions regarding the ODB2 on my Ex.
I have available a cable, but no software.
What is reccomended to use in order to:
-read out diagnostics
-change values (ie. setting idle to something more sensible than 1000rpm)
Old Apr 18, 2008 | 01:44 PM
jhouge's Avatar
jhouge
Hmm...No one?
Old Apr 18, 2008 | 03:35 PM
Monsta's Avatar
Monsta
Sit. Stay.
Other than a custom tuner or your Ford dealer, I know of no products out there that will allow you change the idle value.
There are tuners that allow you to change performance parameters (engine tune, tire suize etc.) and give you the ability to read & clear trouble codes.
I've also seen software...Autotap... AutoTap - OBDII Diagnostic Scanner ...that lets you read your engine's sensors in real-time via the cable you have and a laptop.
Does your truck idle at 1000 when running propane? maybe it needs a high idle? What changes were made to the engine computer to allow it to run propane?
Old Apr 19, 2008 | 03:29 AM
jhouge's Avatar
jhouge
It idles around 1000 on petrol (900 to 1000) and roughly 100 higher on propane.
It always start on petrol, and switch to propane when the engine is around +35 C, so the high idle on petrol could be related to cold start.
I have a friend with a 2001 Ex, same engine and LPG system.
His car idles around 650.
The propane system have 2 brains, 1 for each side of the engine.
I don't know if the main controller is working as a master to these 2 units, or if they live a life of their own.
I've sent a request to the workshop who installed the LPG system.
