Brake question
Old Apr 16, 2008 | 09:42 PM
rmalottwtes30's Avatar
rmalottwtes30
Brake question
What size brakes are on a 3/4 ton Dana 60 rear end?
I am going out and buying things this weekend.
I'm getting....
Hardware kit
Brake Adjustment lever
Brake Adjustment cable
Brake Adjuster
Brake Shoes
Wheel Cylinders
Anything else I should need?
Old Apr 16, 2008 | 09:55 PM
uncle.stosh's Avatar
uncle.stosh
Ryan, nobody minds helping you but you HAVE to learn to search........
Old Apr 16, 2008 | 10:23 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The size of your brakes will be stamped on the brake drum.
Either 12 x 2-1/2 or 12 x 3. Depending on your GVWR.
Don't forget brake cleaner, Brake Grease for lubrication, and a lot of DOT three brake fluid to flush that contaminated fluid from the system, as you mentioned in the other thread.
good luck.
Old Apr 16, 2008 | 10:29 PM
rmalottwtes30
Ok thanks guys. Sorry Ill try to search more.
Means I gotta take my wheel off again. HA HA!!!
Yeah brake cleaner and grease would help. Dont gotta worry about the Brake fluid I already got 3 big things of it!
I don't know the history of the truck so I'm just replacing everything in the rear end associated with the brakes.
