vents plugged
Old Apr 16, 2008 | 08:41 PM
rmalottwtes30's Avatar
rmalottwtes30
vents plugged
I took my bed off today and seen that my vents for my diesel tanks are plugged with bolts. Are they suppose to be plugged or open?
I also unhooked my fuel gauge wire and got a jumper wire and jumped them over and the gauge went up. That means it is in my sending unit correct?
Old Apr 16, 2008 | 08:49 PM
uncle.stosh's Avatar
uncle.stosh
If you grounded your wires directly and your gage works, then yes your sending unit is bad.
What sending units do is vary the amount of ground just like a variable resister (potentiometer).
Old Apr 17, 2008 | 01:43 PM
rmalottwtes30
Here is what I was referring to as to the vents plugged. Thanks
Old Apr 17, 2008 | 01:51 PM
Archion's Avatar
Archion
Veteran: Marine Corps
That looks more like a vent cap to me, kinda like a mushroom
Old Apr 17, 2008 | 02:06 PM
rmalottwtes30
No im positive its not, the end is completely blocked off.
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yeah, I would leave that alone.
Old Apr 17, 2008 | 02:22 PM
rmalottwtes30
ok will do, even the back tank since its got a bolt in it?
Old Apr 17, 2008 | 02:58 PM
81-F-150-Explorer
If it's actually got a bolt in it, then no. you need to get another vent cap, like the one that is pictured.
Old Apr 17, 2008 | 04:07 PM
rmalottwtes30
What I did was switch the vent hoses. Since I don't use my front tank(Cost to much!)
Is that why it liked to splash at me when I fill it up?
Old Apr 17, 2008 | 04:43 PM
81-F-150-Explorer
What I did was switch the vent hoses. Since I don't use my front tank(Cost to much!) Is that why it liked to splash at me when I fill it up?
It's a possibility.
Also if I were you, I would fill both tanks, and run off of each tank in turn.
What I do is I run off my front tank to half a tank, then run the rear tank to half a tank and then fill it up.
This will keep the tanks from rusting, and collecting water, and you still are only using one tanks worth of fuel at a time. And in an emergency you have the fuel if you need it.
