draining HFCM question?
Old Apr 16, 2008 | 06:30 PM
diesel_dan's Avatar
diesel_dan
I drained a bit of fuel out of the HFCM today for the 1st time -- no water and fuel is too dang expensive to let it drain for long! Question is: how tight is tight-enough on the drain plug? It came off really easy, and I just snugged it tight (Tech folder says NOT to overtighten). Still, would hate for it to back out at some unopportune time... No room for a torque wrench in there either...
Thanks.....
Old Apr 16, 2008 | 07:11 PM
Diesel Smoker's Avatar
Diesel Smoker
Hand tight will be fine it seals with the o-ring not threads.
Old Apr 16, 2008 | 07:35 PM
diesel_dan's Avatar
diesel_dan
Thanks, Man -- that's what I needed to hear...
Old Apr 16, 2008 | 09:24 PM
moebdick's Avatar
moebdick
After I drain my HFCM I pour most of it back in the tank, being careful to keep any water from pouring in. I save the rest in a jug for cleaning paint brushes and things.
Old Apr 17, 2008 | 07:01 AM
Herkmafia's Avatar
Herkmafia
I use a two liter coke bottle (cleaned out) with the top cut out. Doesn't spill a drop, i can see any water or trash and I can pour it back in the tank easily by squeezing the top into shape.
Old Apr 18, 2008 | 04:05 PM
Foamy's Avatar
Foamy
I also have a question/problem changing my fuel filter on my 2004 E450 RV.
In the tech files and all other sources I could find it shows this filter mounted horizontally to the body frame and it has a drain plug.
On my rig the filter is mounted vertically and has a knurled **** with a spiggot on the bottom as the draining device.
When I turn the drain **** fuel comes out, but it will not stop flowing. So I can't risk undoing the filter housing knowing that fuel will continue to run out. This would continue until the tank is empty I presume !!
Is there a way to shut off the fuel from the tank or has someone any other ideas on how to stop the fuel from running into the filter while I change it?
While I am here maybe someone could clarify that I have the proper filter.
My local Ford dealer tells me there are two types of filters for this vehicle, one for the truck and one for van ??
We "guessed" mine was a van so he sold me part# FD-4606 4C2Z-9N184-B4. This has a short, squat primary filter. The other version is taller and skinny??
Here is my VIN if it helps 1FDXE45P44HB02840
Old Apr 19, 2008 | 11:12 PM
fpd7's Avatar
fpd7
Well, I can attempt to answer the first part.....You want to be sure your fuel tank is low, and the HFCM won't drain out for long.
If the tank is full, a lot runs out. It won't empty the tank, but about a pint or so. If the tank is full, it starts to run out and seems like it will never stop.
Just be sure the tank is low, like 1/4 tank or so, and you'll be fine.
At least, that's the experience with my F-250.
Hope this helps.
Old Apr 21, 2008 | 10:00 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and if you can, park it so the front is higher than the rear.....this also helps.
Old Apr 21, 2008 | 10:04 AM
lupe803's Avatar
lupe803
Does having the truck parked with the front end higher help stopping the fuel come out less and will the water still come out first?
