6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Bio-diesel ?
Old Apr 16, 2008 | 05:20 PM
Mnytalks1's Avatar
Mnytalks1
Bio-diesel ?
Can Bio-diesel be put into these 6.4L engines?
Old Apr 16, 2008 | 05:44 PM
rmosso1's Avatar
rmosso1
I filled up at Walmart on Zebulon in Macon, GA a couple days ago. The green label said ULSDF less than 15 ppm sulfur, and it said, 10% bio. I put in 30 gallons. I hope mine don't blow up. My only experience.
Old Apr 16, 2008 | 06:27 PM
tex25025's Avatar
tex25025
The only concern would be the filters clogging especially when you combine the good lub qualities of the bio clogging up 6.0 filters and they aren't as particular as the newer ones. I would keep filters handy even running 10% until you know how even that low affects it if you use it on a regular basis.
Old Apr 17, 2008 | 03:43 AM
SouthTexasDiesel's Avatar
SouthTexasDiesel
The maximum amount of Bio-Diesel that can be run in these trucks is B-5, which is 5% Bio. Any more than that and you are risking damaging the DPF on the exhaust, which isn't a cheap fix.
Old Apr 17, 2008 | 05:40 PM
BadFord93's Avatar
BadFord93
Ive been running B-10 for awhile and i have 16000miles on the truck...i dont run it every tank but the sticker was there on the pump at Piolt in Monroe when i filled up when i first got the truck but later it wasnt...and i jsut noticed it back again so im sayin forget buyin it there..but anywho nothings happened to my truck yet..
Supercab
6.7L Power Stroke Diesel
Aug 9, 2016 12:19 PM
Supercab
Jun 27, 2013 06:44 PM
quehegan
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 6, 2012 08:30 AM
Olds69442
Jul 25, 2012 08:30 PM
DynamoDale
Feb 29, 2012 11:00 PM
