5.4 engine checks and tune up
Old Apr 16, 2008 | 07:36 AM
madcatter33's Avatar
madcatter33
Ok since I will probably be keeping my F250 for another summer what are things I should do as far as tune up things and claeaning.Anything that can cause loss of power/preformance/gas milage over time.I already changed the plugs,cleaned the MAF,getting a new IAC valve and have a K&N air filter.Is there anything else I can clean up and/or replace?Anything whether big or small.I figure I might as well do everything I can since I have all summer.Gears will come after I have all the maintenance/tune up stuff done.Thanks alot for any input.
Old Apr 16, 2008 | 07:33 PM
LxMan1's Avatar
LxMan1
Change PCV valve and check it's hose asswmbly front and rear for cracked or really soft elbows.
A tranny fluid flush would be good too, as well as a coolant change.
Old Apr 18, 2008 | 06:33 AM
78fordman's Avatar
78fordman
how many miles are on it, if o2 have over 120k on them probably would not hurt to change the two upstream ones.
FordAnger
15
May 6, 2025 06:22 PM
kg6mov
Aug 28, 2014 06:11 PM
WhiteBeast-05-powers
Nov 9, 2013 12:47 PM
Neil64
6.4L Power Stroke Diesel
Aug 4, 2010 01:11 PM
glu252
Feb 12, 2005 06:53 PM
