Minimum rotor thickness
Old Apr 15, 2008 | 01:24 PM
atrident's Avatar
atrident
Does anyone know the minimum for the front rotors on an 03 Expy. Yes,I know its stamped on the rotor but its real rusty and I am not able to see anything.
Old Apr 16, 2008 | 12:36 AM
lsrx101's Avatar
lsrx101
Basically, if you can't read the spec cast into the rotor, it's time to replace them. The rust that obliviates the stamp has also attacked the internal webbing of the rotor. If you get it machined, it likely will cause a pulsation concern in very short order.
Any good shop that can machine your rotors will have access to the minimum spec. info. If they don't have access to that spec, find another shop.
You will likely find that the rotors are worn to the point that they cannot be machined.
Old Apr 16, 2008 | 10:12 AM
buzzard's Avatar
buzzard
For 2000's it was 27.7mm.
tonyl2547
Escape & Escape Hybrid
Feb 6, 2015 05:06 PM
browntown3
2004 - 2008 F150
Mar 21, 2012 12:03 AM
week0019
2004 - 2008 F150
Mar 22, 2009 12:17 PM
cangim
Feb 22, 2006 08:34 AM
jetta4
Feb 6, 2005 05:58 PM
