Any Harm??
Old Apr 15, 2008 | 01:26 AM
TOUGHLover's Avatar
TOUGHLover
Any Harm??
Would it do any harm to OVER-fill (like nearly full) the antifreeze/coolant overflow/recovery/expansion tank (bottle)? What about concentrations of antifreeze/coolant of more than 70% - is that harmful??
Old Apr 15, 2008 | 08:03 PM
lonerangerinaz's Avatar
lonerangerinaz
Wont hurt anything to overfill your expansion tank, it will just leak out of the cap on the tank if it needs more room to expand.
If you have more than a 50/50 concentration of anti-freeze that itself wont hurt your truck but it does hurt how much heat your coolant can coolect and remove so your truck will run hotter and could over heat which will damage your engine. 50 percent anit-freeze is about the most you want to run.
I knew a guy once that ran about 80 percent anti-freeze and fried his Mustangs motor the first summer he drove it here in Arizona. Anti-freeze raises the boiling point and lowers the freezing point but it doesn't help your cooling system remove more heat.
Old Apr 16, 2008 | 12:11 AM
lsrx101's Avatar
lsrx101
50-50 is the recommended mix of Anti-Freeze to water. More water you risk freezing, less water you risk boil over. Variations from 50-50 are area dependent.
In Arizona, a bit more water can't hurt. In northern Maine you might want a little richer mix of antifreeze.
Here in the Midwest we generally do 50/50.
It's really not rocket science, but straight Ethylene Glycol coolant doesn't do a good job at either extreme by itself (or so I was taught).
IIRC, it can get slushy at around -10F and boil at about 220F straight from the bottle. It needs water to broaden the range of protection.
smokersteve
2009 - 2014 F150
50
Sep 20, 2023 10:01 AM
Huckle berry
Sep 17, 2016 12:52 PM
milliesdad
2004 - 2008 F150
Dec 21, 2015 10:51 PM
mmenzies
Jul 3, 2011 04:07 PM
jimkidd
Dec 31, 2005 12:06 AM
