With the high cost of fuel has any one had any experiences with propane injection? If you have what kind of system and do you have any increase in mileage? I pull a large 5th wheel and have the power but would really like to break out about the 9-10 range if possible. I know that horsepower needs to be fed and maybe the propane would do it. Thanks.
This may sound like preaching, you can increase your mileage without any added expense. I transport RVs and when I first started I thought it was great to be able to run 70 or 75 out west. What I only found out through experimentation is that I would only get 10 mpg at 65 and as low as 7 mpg at 75.
I did a lot of reasearch and trials and found that on the 7.3l PSD with an automatic (E4OD or 4R100) if I ran based on my Tach instead of Speedo. Set your crusie or foot at 2k rpm and you should find your mpg go up to 12-14 depending on the weather of course. It is about 62 mph.
I have found that I would rather spend 5 minutes an hour driving than spending more money on fuel. Even as a transporter that is about 1 hr per day (loaded) but my savings on a west coast delivery (about 2300 miles) is in the area of $300. Mileage is what makes my money, not time, so I gain alot for the little time I loose.
I have seen some ads in Diesel Power that claim 18 on fuel and 26 with propane, but I keep asking: "Why isn't the trucking industry doing it if it works so good?" I've priced some propane systems and all told they go for about $1500 for the parts. Now that does not include installation or any other mods that might be needed or "strongly suggested" such as head studs. There is a forum lower down for this subject, that might be a good place to check out...
Safety. Warranty. Superstition. Not necessarily in that order
