Carb heat hose
Old Apr 13, 2008 | 10:30 PM
sleep_deprived129's Avatar
sleep_deprived129
Carb heat hose
I currently do not have a heat hose on my carb(goes from exhaust to choke if my term is not correct). My truck runs just a tad bit on the rough side, so I was wondering, would the absence of this hose create a vacuum leak of some kind?
Old Apr 13, 2008 | 10:34 PM
Freightrain's Avatar
Freightrain
That vacuum is from ported(above throttle plates), so it's NOT a leak.
It draws just enough vacuum to pull heat from exhaust to heat the choke coil.
How's the tune up? Plugs? wires? etc.
Old Apr 13, 2008 | 10:37 PM
sleep_deprived129
Wires are nearly new, plugs look like they're ok, kinda wet on the outer parts but the middle is jus kinda brownish/reddish but not wet, almost looks like it's kinda rusty.
