Swapping a 302 for a 351w
Old Apr 13, 2008 | 08:48 PM
Manic Mechanic's Avatar
Manic Mechanic
So if I was to swap a 351W in my truck, what do I need to do? Its a '94 F-150, automatic transmission, 2wd. OF course its fuel injected, and thats what I'm worried about. Do I need to get a new ECU for the 351W, or can I use the factory one for the 302 in it now? Was really curious cuz I may goes this route or get a built 302. Thanks in advance,
-Eric
Old Apr 16, 2008 | 08:23 PM
lostin90s's Avatar
lostin90s
Is it MAf equipped ? If so you r OK with ecu it will do fine with the 351. If not need a ECU
But there r flywheel diffs . But the firing order is same so if you have a pan to intake 351 your in business.
