fuel tank selector switch
Old Apr 13, 2008 | 01:27 PM
thurt's Avatar
thurt
I have a 1994 ford f150. When I switch to the front fuel tank the truck goes dead. The tank is full. Any suggestions on troubleshooting?
Old Apr 13, 2008 | 05:07 PM
bronco2454's Avatar
bronco2454
It could possibly be a fuel pump problem.
Old Apr 13, 2008 | 11:03 PM
EPNCSU2006's Avatar
EPNCSU2006
Sounds like a failed fuel pump. When you first turn the key to the run position while the front tank is selected, can you hear the pump hum for a couple of seconds? You can test the switch to rule it out, and I would expect the relay to be fine since the rear tank works.
Old Apr 16, 2008 | 08:15 PM
lostin90s's Avatar
lostin90s
I';d check switch first . Its easy . But the pumps will die with no warning.
