New Holley Carb
Old Apr 13, 2008 | 11:50 AM
64F-100's Avatar
64F-100
Question New Holley Carb
I just can't seem to get the Autolite carb on my 292 right, so I have decided I'm going to buy a new (re-man) Holley. The part number is 64-5043. Will this fit right on in place of the Autolite?
64-5043 is the only replacement number anyone can give me for my Autolite...
Old Apr 13, 2008 | 11:21 PM
bigblockford_390's Avatar
bigblockford_390
To my knowledge Holley 2 barrel carbs bolt right on in place of Ford 2 barrels. Holley carbs have the same bolt pattern and I have swapped a few Ford two barrels out with Holley's.
That is not to say that there was an odd ball Ford or Holley made but you should be good with the swap.
Jeff
Old Apr 14, 2008 | 08:56 AM
JimKoz's Avatar
JimKoz
Holley rebuilds all makes of carburetors, so the 64-5043 should be identical to the Autolite 2100 that you have now.
If you want a genuine Holley carburetor you'll want the Model 2300, which has the same bolt pattern as your Autolite. I don't think that Ford ever used that carburetor, so you'll have to get one for another application.
International Harvester used the Holley 2300 for many years, so you might try one to fit a late '60s IHC with a 304-V8 engine (closest in size to the Ford 292). I've got a 1969 3/4-ton with a 304-V8 and is uses part number 64-3137, which is also remanufactured, but it is a genuine Holley carburetor.
If you want a brand-new carburetor, Holley makes a 350-cfm universal version of the 2300 that is part number 0-7448.
Holley Performance Products 350 CFM Two Barrel Carburetor*0-7448
http://www.holley.com/data/Products/...199R7950-7.pdf
Old Apr 14, 2008 | 08:58 AM
64F-100's Avatar
64F-100
Awesome guys! That is the info I was looking for.
Thanks!
Old Apr 16, 2008 | 11:15 AM
64F-100's Avatar
64F-100
Installed the 2300 last night...Fired right up and runs smooth now. It was worth the 270 bucks!
Old Apr 16, 2008 | 05:31 PM
JimKoz's Avatar
JimKoz
Did you get the universal 2300 (0-7448) or a remanufactured 2300 from another application?
Old Apr 17, 2008 | 05:32 AM
64F-100's Avatar
64F-100
I got a brand new universal 2300 (0-7448). Price was $269 at the local speed shop. I am very pleased with it. Thanks again for the info on that carb!
I inspected the original carb a bit more, and something I didn't notice the first few times it was apart was that the main shaft that the lower throttle plates are attached to is very sloppy...I think that is why I couldn't ever get the old one right...
hooler1
Jan 16, 2016 08:52 PM
Turb0matic
Oct 17, 2014 05:01 PM
carsofchaos
17
Jan 8, 2014 09:33 AM
SoFla64
Oct 7, 2010 10:59 AM
Raptor119
20
Aug 11, 2009 06:24 PM
