how much power will i make??
Old Apr 13, 2008 | 01:26 AM
86BroncoGuy's Avatar
86BroncoGuy
i have almost finished a 347 stroker and i am wondering what kind of power it should be making, it has
-347 streetfighter kit with aluminum flat top pistons
-edelbrock performer rpm heads
-crane roller rockers
-holley 750
-holley 110 fuel pump
-hooker long tube headers
-super agressive lunati cam 2500-7500rpm
-timing GEARS(not chain)
im trying to decide on which blower to go with and im thinking the wieand one that does 6-8psi... im still looking around though
the block was bored .30 over, and 0 decked, and the internals were all balanced and blue printed
im just wondering what kind of power to expect... thanks for your help
Old Apr 13, 2008 | 02:13 PM
Franklin2's Avatar
Franklin2
Do a search on the web for a virtual engine dyno or something like that. They will let you plug in all your specs, and give you an estimate. Here's one I found, and of course you have to pay for the main program, but I see they have a freebe up in the corner. I will let you check it out and do the searching, I didn't have time.
Old Apr 13, 2008 | 10:14 PM
Franklin2's Avatar
Franklin2
Someone reminded me I forgot something in the above post. The link would help wouldn't it? The problem is I did another search and came up with a different one.
Welcome to Virtual Engine Dyno - The Ultimate in Engine Simulation Software
Here's another.
Hotrods & Classic's Virtual Engine Calculator
I haven't tried any of these. If you have a fast connection, and find one that you like and is easy to use, maybe you can write back in. All I have is dial-up, so it would take me forever.
