Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Briggs engine?
Old Apr 12, 2008 | 07:44 PM
70blue's Avatar
70blue
Briggs engine?
I have a 3 horse horizontal shaft motor that I am tired of dealing with points on. I was wondering if the flywheel and coil off a 3.5 horse vertical motor will fit on it and upgrade it to electronic. This is not the antique 3 pole coil it has two poles. I know I can buy a magnatron upgrade kit but I can get the blown push mower engine free to rob parts off of if they will work.
Old Apr 13, 2008 | 06:34 AM
GlennFordx4's Avatar
GlennFordx4
Yes but you don't have to change the flywheel as long as it is a 2 pole coil.You must change the flywheel key to one for electronic ignition.
Old Apr 14, 2008 | 06:42 PM
ckal704's Avatar
ckal704
I agree. But I never knew there were different flywheel keys for Briggs engines. I know Tecumseh has about a dozen different flywheel keys, but I have only ever seen the one version for Briggs engines. This is surprising news to me, Glenn!
Old Apr 15, 2008 | 05:41 AM
GlennFordx4
When they went to electronic ignition they changed the material of the flywheel key and it is the only key you can buy now.
If you had a old engine with points the old key was raw aluminum and the new key(electronic) is a aluminum alloy.
If you have the old points key and use it with electronic ignition there is a chance it will kick back and shear.
Just one of those things you learn when you were young and never forget!
